Camry Sportivo Gen 6 (2006) bulbs
allanlol86
Hello guys
I just bought my Camry Sportivo and I would like to change the lights but after a lot of research, I am really confused about the bulbs.
On the manual, it says the following:
- Low bean - H11
- High bean - HB3
- Fog lights - H11
But when I opened the hood to check the low bean, it clearly is H7. I was wondering whether the fogs are also H7.
The strange thing about the manual is that it says "AURION" on the cover despite the content inside itself is about Camry.
Could anyone also teach me how to remove the low and high bean bulbs? I tried to just pull them but no luck x(
My car: 2006 Camry Sportivo Gen 6.
Many thanks!
I think you have the aurion manual instead of the camry. My manual says H7 as low beam!
Haven't tried the high beam yet, but the low is easy, just take the rubber cover off, reach for the bulb and twist it counter clockwise, If you are referring to actually removing the bulb from the socket, you just yank it out use some sort of sharp tool cos it might be hard if the bulb hasn't been removed for a while.
The bulb's two legs slots on the socket,
      Fuel Filter - Change or not
      2013 cruiser gxl ute
      help with clutch
    7. 3
      newbie from Queensland
      High mileage camry
      1981 Hiace ignition upgrade
    10. 2
