distributor
spec_black
not sure what it is
but on the raizin guide
its one of the wires have to be connected there
cant seem to find it
i found something thats similar
but not sure if thats the one
the one im talking about is on the right hand side of the engine
i dont know if thats it
yeah
giving me the ****s atm
gonna see if its under the engine cover tommorow
if not
ill take it to my uncle
see if he can find the little thing
if he cant find it
hopefully someone on this forum knows where the coil is
Dude, its only the sparkies under the engine cover... maybe you can follow the wires?
Hey how did you undo the bolt to the throttle body and the alternator? Mine are soo tight i can even move them!
just installed the thing today
wasnt as easy as it seems
couldnt find the distributor or the distributor coil so i didnt attach the grounding wire there
anyway i took piks of every point of the cable connections
but cant attach them on the forum
no more global space left
-_-"
if anyone needs help with installation you can give me a call
or ill send you the images of every point
also make sure u use power tools!
i used hand tools
took ages
about 1hour an a half
well most of the time was spent looking for the distributor
      New member seeking advice for parts
    2. 39
      Pics of my Kluger steering wheel removal
    3. 14
      1zz to 2zz
      Can I put a 2010 bumper on my 2008 Camry ?
      Anyone else tried these seat covers ?
      Digital Speedometer
      am2 fuse blowing
      Toyota Celica '96 5S-FE no spark
      Toyota Camry 2003 Driver seat recline issue
