Noise near the belt
Silly_kah
https://www.youtube....be_gdata_player
Toyota Celica 2000 ZZT231
Problem:
squeaks/chirp near the belt/right engine mount
happens when i revs it or turn on the AC it doesnt always happen though
I had recently changed ES front and rear engine mounts and also suspension bushings
belt is goodyear gatorback approximately 1 year old and did 23000kms
i used silicone spray on the belt, the belt has no damage or cracks at all, it seems like its aligned properly
Suspicion:
either right engine mount or one of the pulleys and tried tightening the right engine mount but noise still there
And also if i put pressure around the headlight area, the noise goes away
Any help/ideas guys?
Edited by Silly_kah
Air con compressor can be noisy with its internal clutch , and the noise can be intermittent as clutch engages/disengages.
If you put the plastic covers back on the noise might not be so noticeable.
      ZRE182 Nudge bar
      2016 Hilux SR5 Coolant Issues
      What to say!
    7. 4
    8. 4
      RATTLING CAMRY 2013
