Excessive vibrations when lights and a/c on
fivese7en
Hey guys,
My car is vibrating a lot when I start the engine and after 10 minutes turn lights or a/c on and stop at a traffic light - is it normal?
I got my alternator fixed 3 months ago by dealers mechanic because one of the diodes blew.
Absolutely not normal mate. Should be smooth-as. You said it vibrate after you started the engine, so it could be fuel related (eg fuel injection).
More like after I turn on different features like a/c after I start the engine - but it only happens when I stop somewhere or at a traffic light
Edited by fivese7en
Its fan, a/c lights etc. anything electrical - I thought it might be the alternator?
I got service in January so might as well get it check out then. Any good mechanic's in the area aem?
      Drive shafts
    3. 10
      front brake calipers
      Drive shafts
    7. 315
    8. 10
      Dashlight dimmer
