JJCRU23R - NISSAN CUBE3
JJCRU23R
Nothing keeping it in place from behind..
kill switch and 7.5 meters of wire
gauges vs shelf.. I used cable ties to keep guages in place in the back
2 will be come one..
3 positive wires joined to one.. then crimped and will connect to the kill switch
masked off and marked out.. no actual measurement, line of sight mostly.
drilled the holes, then joined the dots
after some fine tuning with a stanley knife and woohoo!
A-ha moment as I realised my guages needed one of these to keep in place.. 1DIN radio bracket/holder.
Realised the bracket was mm's too wide.. needed to cut the bracket in half and rejoin it, cable ties keeping it in place.
Tabs on the sides of the bracket brilliantly keep the guages from falling back
Switch installed and (+) wires connected
1 of 3 connected!
dont know what happened with this pic...
but the sensor wires for the fuel/air gauge and the water temp guage.. all the other wiring is in place which means I shouldnt have to remove the dash for any reason. the guages are grounded and powered. these 2 wires are all that needs to be connected to complete the install. Poked these wires through the firewall with an old metal coat hanger.
stock photo of how the radiator sensor will be installed.
currently waiting for the blue radiator sensor adaptor from ebay through the mail.. ordered it 31st Dec 2013.
Had to connect the fuel/air gauge to the O2 sensor.. was a case of guessing which 1 of the 4 wires coming out of the sensor should I tap into? Turns out it was the black wire... 1st wire I tried.
I was hoping to have all 3 working before my holidays end but the radiator sensor adaptor is still in the mail, which sucks because the temp gauge is the one I needed most out of all three gauges. The cube only has a blue light and a red light to indicate the temp of the engine so the temp gauge is important.
It has been very interesting to see what drains the battery when I use things like the lights, auto windows etc.
  • 1 year later...
Over a yr later... time for an update!?
11050304_10153671761173572_3275975052649
Gettin annoyed royally in traffic and not satisfied with the Nissan sport horns my Cube came with... so the Yankee horns get to blow out a 3rd car!
IT TWERKS!!!
As for the Gauges... all are functional... but I can see why they were the cheapest on ebay. The LEDs fitted in them arent reliable. All 3 of them have at least 1 of the LEDs malfunctioning.. in daytime its hard to see but at night, the LEDs that do work make it possible to see the temp at night.
The horn was the last mod... done last month.
I scored some satin black vinyl wrap and put it to good use on my dash..
10474809_10153418048513572_2721552969106
Trial and error a plenty10700766_10153418011863572_1561835521302
Removed all the bits off the stereso surrounds
Screenshot_2015-04-03-20-41-22_zpsfrgrqb
Came off nicey
Screenshot_2015-04-03-20-41-39_zpshvikht
10644265_10153457984243572_5823623221943
After much wasted wrap.. even when done well, when the car got hot inside, it tended to wrinkle up. Will respray it eventually when Im bothered.
Before the wrap job... was the DRIFT CUBE RC project...
10636666_10153383794233572_6218929265680
Got it completed and was lucky enough to show this bloke @ the end of yr JDMST meet @ Eastern Creek
Based on a legendary cube from Thailand, I contacted the owner via FB and gained his permission to replicate his car in RC 1:10. top bloke!
10370710_335107513314962_1649494459_n_zp
Started off with a awd Tamiya TT01D with skyline shell... too big to use as is.. but there exists a conversion kit which I bought quick smart to get the cube going.
3 racing conversion kit
I used most of the existing bits from the TT01D and substituted some with the bits in the conversion kit for a smaller wheelbase
