Posted (edited)
Hi all i had to fix,s an oil leak on my wife gen 6 1994 st204
in the oil pan
ok got that done but it is not the only one !!
it is leaking down the side allso where the timing belt is :(
i know most common issus with toyotas this old seem to be the following
cam seal ,crank seal ,oil pump seal ,oil pump o-ring
but i have never done one ?
what is the best way to go about it ?
does the engine have to come out ?
thanks lots remo
Edited by remo
you dont need to pull the engine to do these seals, although it is a pain in the *****.
you will need to remove the RHS top engine mount and support the engine underneath, pull the timing belt cover, timing belt, pullys, etc
its probably a good chance to replace the timing belt, etc too
  • 4 weeks later...
Posted (edited)
How many k's has your car done? The most common leaks on the cambelt side of the motor are:
180,000k - the rocker cover gasket (happens on most Toyotas)
200,000k - the power steering box (just keep topping it up. They need to be removed and recod' - not expensive)
200,000k + Change the oil pump o-ring ($100) when you do your cambelt and your water pump ($75)
Not sure when cam or crank seals go, but youd want to do these at 300k
Edited by Excalibur
  • 5 weeks later...
thanks guy sorry to not get back to you sooner what a job it was !! i never like to do that one again
      Remote start
    6. 10
    7. 10
      Turboed Corolla Overbuilt?
    9. 3
    10. 3
