5LE (LN167R) kw boost suggestions
basdg
2 wise statements from them I learned from:
Only milk and Orange juice come in 2Liters.
There's NO substitute for cubes!
& my own:
If you really wanted power, you should have bought something powerful.
Otherwise just be quiet and enjoy the ride.
To make it clear-do not turbo a 5L nor 5LE motor-Mr. Tojo built a new engine so he could turbo a 3.0L diesel. It was not a free choice, it was a necessity!!!!!! I doubt any significant improvement can be made without risking premature head failure.
The L series motors have a history of head failure due to inadequate cooling. [Typ around 250,000km] The only safe one known to turbo is a 2L-T, but even those have problems. There is a Chinese allow head for the very first L series motor [with rockers], if you wanted to import one. Fitting a turbo to a 5L/5LE dramatically increases the thermal load on the iron head, ecouraging early failure. If there was an alloy head, you might get away with it, but I suspect the block is also on its thermal limits, hence the new engine to handle the heat.
Sorry to disappoint you, but that's the way it is.
Edited by Manxman
Thanks for the detailed info.
To be honest I wasn't contemplating doing the turbo upgrade as I am of the belief of your first statement.
I was hoping there'd be other mods (other then turbo) even if it were to boost by a lesser margin, however it does not appear there's anything out there.
      Engine Cost for Sportvito SX6 2007
      Passenger footwell wet ? roofracks?
    5. 5
      Camry Navigation System
      N80 2015-2017 infotainment upgrade
      Hello There
      Central locking
