Problems With Cold Starts
Cappakazi
Hi there can anyone give some handy advice to newbie?
I am having difficulties starting my car only once its been left overnight (only no other times) i try to start it and it just clicks some times it start 2nd of third go sometimes after like 10 attempts every other part of the day it starts fine.
It has a brand new battery also.
Model of my car is Supra 90 7mgte Ma70 GT single turbo
Any advice would be much appreciated
Check the cables and connections, maybe a bit of CRC to help. Also check the alternator is connected correctly and working well. You can get moisture in the components if you have cleaned the engine bay. ;)
  • 1 year later...
      help with clutch
    5. 3
      newbie from Queensland
      High mileage camry
      1981 Hiace ignition upgrade
    8. 2
    9. 1
