Clutch burnout
oliver_twist
Good morning all,
This morning I was going to do the trip that I was waiting for... However after 50km my gears weren't responding: burning smell and impossible to move (changing the speed gear was doing nothing) so towing etc etc
I m not a mechanic expert but I would like to know if it's easy to do?
if not I will need to go to one next Tuesday: what should I be careful at, what s the price average?
Thanks a lot for reading it and your advices.
Oli
well it sounds like you have killed the clutch. your best avenue if you do not own a hoist and the correct tools will be to ring a couple of garages and get quotes .
the gear box needs to be removed and the flywheel machined you should have the rear main oilseal replaced at the same time the gearbox is really bloody heavy
obtain a manual and it will help you if you wish to undertake the job
rough pricing clutch kits start around $350 can get upto 600 easily depending on brand and type
flywheel regrind about $60
and labour around 6 hours at 100 an hour $600
as i said this is a rough guide
      O2 sensor
    2. 0
      Tray swap
    3. 8
      Best Oil for 2014 Lancruiser GXL 200 series TT V8 Diesel
    4. 4
      Average Fuel consumption display
    5. 5
      Error on my navigation system - Land Cruiser
    6. 3
      2000 Hilux Clutch replacement
    7. 0
      2020 Camy Hybrid EV battery problem.
      Vault Carry
    9. 6
      Steering shudder
    10. 0
      Reverse sensors - how to disable
