Hi my missus owns a toyota camry 2006 model. The car has been perfect and no trouble at all. Just recently though the rear left hand door isn`t locking or unlocking when activating it with the key remote central locking. It almost seems like nothing at all is happening, you can`t even hear the solenoids moving inside the door. All the other doors are working fine and as per normal. Im about to remove the door trim to try and have a look to see whats happening. I already tried spraying some rp7 into the locking mechanism but that didn`t change anything. Does anyone have any ideas?
My other question is how do i remove this type of door trim? I already popped out the plastic behind door handle and removed that screw, but what else do i have to do, i don`t want to damage anything. Also i could see behind the door trim, in far left top of trim, there is a white plastic electrical connector which isnt connected to anything, im thinking this could be the problem, its come dis-connected.
Problem fixed!!
It was the white connector block, i pushed it into hole in door and i heard it click and lock in, then the lock was working again with the remote, some how it came loose and dis-connected or maybe some one never put it in properly previously to us owning it. I didn`t manage to get the door trim of, i just pried it open, plugged the switch in and pushed door trim back in. Would be good to know though how the door trim comes of still.
