connecting led's to 2011 camry atara s dome light
cams
Hi all,
Im trying to connect leds to my 2011 camry s atara dome light and not sure which wire it is. I have read posts about connecting to a wire behind the glove box on an aurion. Is this the same for my car or not. I see 3 cream / green strip wires coming from the dome light down the a frame pillar to a connector then onwards to down behind the dash. Could I tap into one of these if yes which one then. If its the one behind the glove box could u tell me which one then cause the posts talk about a red one and orange one and white one with pictures which don't seem to load.
Cheers...........
Edited by cams
Hi all.
I found the wire I needed. Tapped into the looming from the dome light running down the A frame pillar.
Cheers...............
    3. 21
    4. 21
    5. 21
    7. 3
      Selling vintage 1996 hilux
      2020 Corolla service question
    10. 7
      Help - Blowing white smoke
