Key Transponder programming
As long as the aftermarket key has the correct transponder chip in it and you have the black master key then it will work.
Sit in the car, all doors closed and no key in the ignition
1. Insert master key in the ignition
2. turn from LOCK to ON 5 times and finish in the LOCK position
3. OPEN and CLOSE the drivers door 6 times
4. Remove the master key
5. Insert the new key and switch ON - The immobiliser light should start flashing
6. After 60 seconds the light will stop flashing
7. Repeat from step 6 for additional keys.
8. Open and close the drivers door when finished to exit programming.
