80 Series Petrol Engine Cut Off Problem
80series93
Hey everyone,
I'm back with another query... This one has me stumped. I've been searching all weekend online for someone who has had the same/similar issue as me but have been unsuccessful so far, hence why I'm posting here.
On Thursday I was driving home from work, had the a/c running. All was good until the engine died. I turned the key off and back on and I had no warning lights (Fuel Tank light, oil light, engine light etc) and the car would turn over fine but wouldn't start. I ended up leaving the car on the side of the road. I went back later that afternoon, put the key in the ignition, and I had all warning lights back and the car turned over 2-3 times and fired into life. I moved it off the side of the road and let it run for 10 - 15 minutes, when it suddenly cut off again. I had no warning lights and the car would crank again but wouldn't start. I smacked the side of the dash and the lights all came back. Started the engine fine. I smacked the dash again and the engine died, and the lights were gone again.
Saturday, after having the car towed home, I pulled the dash apart on the drivers side trying to find the problem thinking it might be a loose connection somewhere. I checked all wires etc and the connectors to the ignition barrel and all looked good. I pulled the kick panel out and made sure all the plugs to the little electrical boxes were firmly pushed in and also made sure all the relays in the kick panel were pushed in. I started it and ran it a few times yesterday and some times it would run for over an hour fine, other times it would die after 15-20 mins with the same symptoms, no warning lights in the dash and turning over but not firing. I have power to everything else in the cab when this happens, stereo, gauges come up, windows will operate, lights and indicators etc etc.
After 10-20 minutes or so, the warning lights will come back up and the engine will fire again. I tried leaving the ignition in "ON" position after it cut out, without the lights, and after a certain amount of time the lights just re-appear and it is fine to start and run again. Seems to run longer if the A/C is switched off, but it will still cut off. So I don't think it is related. Friends have suggested a thermal cut off maybe? But the water temp never breaches 82 degrees so I am struggling to believe this could be the issue. Obviously the issue is not with the engine because when these warning lights come back up and it starts, it will fire into life no issue and runs perfectly fine. No loss of power or anything like that.
So I'm hoping maybe somebody has come across the same sort of issue as what I am having. I'm thinking it has to be something relatively simple.
Would appreciate any input. If I fail on here, then I will have to send it off to the mechanic.
Thanks in advance.
Thanks for the response.
Any idea where I should start? I did check a number of fuses and the EFI relay under bonnet. The EFI relay seems to get really warm. Does this sound normal? By warm I mean almost untouchable.
That is definitely cause for concern, it should not be getting so hot and that may either be a cause or a symptom of the problem. It would be advisable to check the wiring under the EFI relay, in the relay box, hasn't melted.
It may just be a case of the relay letting go. You could simply unplug it to see if the symptoms are repeated, dash lights etc.
This thread may be of assistance to you as it appears a fairly common issue.
http://forum.ih8mud.com/threads/efi-relay-tip-for-quick-diagnosis.622430/
So I have been busy and have only just been able to have a fiddle with the 80. After this issue happened the first time I drove for a good 2 weeks without happening again, and then last Friday it pinned me. Cut off again and had to bring it home on a truck. I replaced the EFI relay as suggested and still the engine will run for a while and shut off. No telling how long or short it will run for.
i did make an interesting discovery though. If I remove the 7.5a blade fuse in the fuse box under the dash, I get the same symptoms. Car will crank but no warning lights when turning the key to "ON" position. Replace the fuse and they return. When the engine cuts out this is the problem I have. No warning lights displayed and the engine will crank but will not fire. I removed the fuse box and checked the connections behind it. They all seem sturdy and none or damaged. I'm led to believe it is an issue with my ignition system. Any ideas as to what would cause this? I am thinking perhaps ignition switch?
Thanks!
  • 3 years later...
  • 7 months later...
have a 80series petrol 94 Blue Marlin manual , the better half was driving home when all the dash lights illuminated and the engine cut out completely , loss of power , no steering and
limited brake pedal response , scary for her , also whilst driving the speedo will "DIP" and odometer & trip meter run backwards, thought they maybe connected , any ideas
  • 1 year later...
I have a 1996 80 series petrol auto.(Engine type  FZJ -80)
Have just experienced a similar experience as Rick Davis's wife.
The engine did restart automatically after a few minutes delay
I did not notice any dash light issues as I was very busy controlling a vehicle with no power steering and limited braking in busy Sydney Australia traffic!
Do not wish to drive vehicle on any trip until the problem can be diagnosed and fixed.
Is the EFI relay the culprit?
Any other suggestions?
Did anyone solve this? I have had a similar issue with a fzj80 with the 1fzfe, will start fine and at random intervals it will lose power and stall out, no remaining check engine light stays on. After time i turn the ignition and restart it as normal and i off i drive for another period of time.
      Towbars
    2. 5
      ASV50 Camry Head Unit Options
    5. 2
    8. 14
    9. 2
      Hi from Wagga
