Stalling problem
Greensr5
Hi all i would like a little help with a problem i have with my 99 sr5 2.7lt. It's stalling on start and then when im pulling up to a intersection. I've replaced fuel pump, leads plugs, iac valve, injectors, battery and air flow sensor in the air box. Please if anyone has any clue it will be greatly appreciated.
When was the last time that you cleaned the throttle body and the idle control valve. I did not do it for about 160,000km on my 1998 Camry then one evening it very unexpectedly would not idle. All was well at 1st set of traffic lights then at the next traffic light intersection it was not idling/stalling unless I was using some accelerator. Now it is something that I do with every oil change or when I check the air filter.
It will stall sharply and sometimes it dies slowly, my icv valve is brand new about 3 month's old, my throttle body was cleaned at the same time.
      Towbars
    2. 5
      ASV50 Camry Head Unit Options
    5. 2
    8. 14
    9. 2
      Hi from Wagga
