Aircon problem?
sasacss
Hi, recently purchased a 2009 Kluger Grande, all good but aircondition is not cold. Started becoming slightly cool after about 5mins but nothing like what I think it should be - any feedback would be appreciated. Thanks,
Time to get the air conditioning system checked and re-gassed. If your car has a cabin filter, check that first. MIne was full of leaves etc so that was certainly obstructing the air flow.
In March 2016, I found a mobile service via Gumtree with good customer reviews. Not disappointed, turned up on time, checked system for leaks etc before re-gassing system. Explained that I should have the ventilation on re-cycle for better efficiency; system not trying to cool the outside air coming in.
Thanks guys, have realised the clutch is not kicking in, I'm hoping it's just a fuse. I've had a look and found the fuse box/compartment but can't find the fuse for the aircon - I will find it and hope that's all it is.
      Upgrade from 2012 to 2023
    3. 3
      Towbars
    4. 5
    5. 2
      ASV50 Camry Head Unit Options
    7. 2
    9. 1
    10. 14
