3VZFE engine floods
Hi guys
Just did rings and bearings on my v6 Camry . I reassembled the engine turned the key the thing fired for few seconds then died.. Smelled fuel so I thought I check the spark plugs and found them very wet.Can anyone explain how this is occurring? Would this be due to faulty injectors? How can I fix this.?
Any contribution on this topic will be appreciated.
Tony Cav
The reason I asked is the 3VZ is notorious for spitting head gaskets.
You will need to get them ultrasonically cleaned and flow tested. There is a good chance the fuel has gummed them up from sitting for so long. There are also mobile injector cleaning businesses, depending on where you live.
      Head Unit with Apple CarPlay
      Any RA 60 owners?
      Bluetooth stopped working
    6. 3
    7. 2
