04 Camry Sportivo A/C lights bulbs
ZRCamry04
Tried removing the A/C unit but its very hard to take out, feels like i'm about to break it, i think the radio needs to be taken out as well. I think the Australian Camry's have a slightly different design dash.
Not sure, i will have to check again, i will this time try taking out the radio as well as i've seen somewhere that the radio needs to be taken out as well.
Look same as US model, use a trim removal tool & pry from bottom & rotate up, it's latched in 3 spots at top. The whole enchilada is clipped in.
