Replacing the glove box lock
GDude
Hi All,
Does anyone know if it's possible to replace the lock on the glove box at all? I see there are no screws on the door so if it has to be done, it looks like I might have to pry it open?
Any advice would be appreciated.
I don't know specifically, I never attempted to pull ours apart; however, here is some general advice:
Keep in mind that Toyota got the lock in there in the first place.
I doubt it will be glued together, so your best option would be to take to the old one with a plastic trim removal tool to avoid damaging the good one. Use it as a test mule.
Start from the lower side if possible to avoid visible damage, if any.
Yeah ok, I thought as much. Will give it a go, maybe with a flathead screwdriver wrapped in cloth. I think I have some trim removal tools around somewhere too.
      LC200 4WD ECU location
    3. 24
      RADIO CODES "HELP"
    4. 2
    5. 2
    6. 2
    9. 21
