Surface Rust on some components under body
Dan Moller
Hi all
firstly g'day all I'm new here đź‘Ťđź‘Ť
just after some advised/reassurance ( hopefully )
we recently brought a 2010 Toyota kluger kxr awd. Beautiful car, drives well, immaculate.
however I have noticed that under the body on the exhaust, brakes ( Discs ) and other metal parts that there is some minor surface rust, there's dirt present so it's obvious that it's been taken off road, but doesn't seem to have been knocked around,
is the rust something to be worried about ?
is there a way of cleaning it off or preventing it from getting worse ?
thanks all
Certainly would not worry about rust on the brake rotors. Presumably you are referring to the vent section. If there is rust on the braking surface of the rotor, it will soon disappear with a bit of driving. Be more concerned about the thickness of the rotors and the brake pads.
Would not be too worried about the exhaust particularly if it is only light surface rust.
You could try applying rust convertor to the rust on the exhaust if you really wanted to.
Thanks heaps mate I didn't think it was much to worry about, the rust is basically anywhere but where the pad touches, it's quite minor.
đź‘Ťđź‘Ť
Edited by Dan Moller
Brake rotors are cast iron, they will form surface rust in a matter of hours (just look at your rotors after the car has been parked in the rain, the pad area will be covered in rust) but it won't ever penetrate deep enough to be an issue.
      1kzte throttle body
    4. 3
    5. 5
    6. 5
    7. 8
      PZQ60-00525 Issue
    10. 3
      Head Unit with Apple CarPlay
Ă—
Ă—
