Hi guys just an update on ACV36R cabin filter, I have been reading forums and watch YouTube videos and found out that earlier model Hiluxes didn't have a cabin filter from the factory but it was possible to cut open and install one.
http://www.newhilux.net/phpbb/viewtopic.php?f=13&t=907&sid=8ea871678508677e7d77b3dfda899127
So this got me thinking maybe we can do the same in our ACV36R Camry's.
So I went to the wreckers and found a ACV36R Camry and start cutting open the slot behind the glove box where the cabin filter should be installed, and yes we can install a cabin filter. The cut isn't perfect as I wasn't used a good knife but the space is there. I found a early model Corolla and grabbed the cabin filter tray on it, surprisingly the Corolla had a cabin filter from the factory and slid the tray into the slot on the Camry and it is almost a perfect fit. Strange why Toyota wouldnt install a cabin filter from the factory as the ACV36R was once Toyota's flagship car. Even the Toyota Echo has a factory cabin filter slot.
    2. 5
    3. 0
      Tow bar
    4. 3
    6. 3
    7. 3
    8. 3
    9. 1
      Snapping wheel and axle studs
    10. 0
