ACV36R Air Location Selector not working
astol87
Well I still havent replaced my Air Selector unit globes, but in pulling one out to identify a part number, the control to select Head, Foot, Demist etc has stopped working. All other dials work, and I've checked the cables are all plugged in, but for some reason just that dial isnt working. Any ideas?
Fuse - just guessing. I changed the globes on my dads recently & it's pretty much plugs to the back of the board, unless the pot which is soldered to the board has become loose ? I would re-inspect the board/pot switch if the fuse is OK.
Do you know what is the part number of the globes? I took it apart, went to Repco, Autobarn, Supercheap auto, but none of them had those bulbs.
i found the issue, forgot to update
theres a little thin metal thing that slides over the upright for that the knob sits on, it completes a circuit from one side of the upright to the other. will take pictures next time i open it up.
Globes btw are T5 and are available at jaycar for $2.50 a pop - https://www.jaycar.com.au/t5-b8-5d-replacement-led-globe-blue/p/ZD0386
      Toyota Corolla Sportivo
      Toyota Landcruiser problems
    5. 7
      selling car
      Fuel Filter - Change or not
      2013 cruiser gxl ute
    8. 2
    9. 2
