Rear Window screen
Internet search located the following Toyota Aurion brochure pdf with a print date of May 2014.
https://www.toyota.com.au/static/vehicles/aurion/content/pdf/aurion_saver.pdf
Aurion Sportivo ZR6 has the electric rear sunshade as standard equipment not the Aurion Sportivo SX6.
Details should be in the owner's manual, if you have one.
Maybe following quote from a BMW Forum is applicable: "" Look at the controls on the driver's door. It should be right under the window controls.""
      Transmission Issue Camry 2010
      Mighty 1991 2WD Hilux lives to fight another day
    3. 6
      Help - Blowing white smoke
      With Toyota entering Aus Super Car racing
      Passenger footwell wet ? roofracks?
    6. 26
      Head unit sd card issue
      Toyota Prius 2012 code
    8. 2
      Engine and radiator leakages
    9. 4
      2018 SL. Reversing camera display stopped being animated.
    10. 1
