2004 2.4 lt Manual AWD tapping
Scott 8233947
Hi all new to this forum but not new to Toyota’s I presently own 2 others and have owned 5 previous To that. I have just purchased a used 2004 Manual 2.4 lt 4 cylinder 4 door wagon with 321k on the clock. Problem I have is that their is a serious knocking (rattling) when the the engine is under load, and a solid thump in the gear box when changing gears. The car is not blowing any smoke of any description. Has anyone any ideas. Thanks in advance Scott
Edited by Scott 8233947
Potential cause is a bad rod bearing.
https://dannysengineportal.com/engine-noise-under-load-faq/
Check for loose or broken engine and transmission mounts.
https://www.google.com/search?client=firefox-b&q=thump+when+changing+gears
      Drive shafts
    3. 10
      front brake calipers
      Drive shafts
    7. 315
    8. 10
      Dashlight dimmer
