Morning readers,
I'm about to embark upon throwing vast sums of money at having my 76 Series remapped by a professional. I should point out I've already gone to the trouble - and expense - of fitting a heavy duty clutch.
However a friend of mine has alerted me to this "iDrive" plug and play system. Has anyone out there chosen to give this device a shot as it seems to be all the rage right now? And for substantially less cost, will I get the same/similar results, or will there potentially be some damaging side effects?
For example; does the iDrive cause your fuel burn to increase dramatically? Could it cause issues with your injectors or any other significant engine part?
Any feedback on this greatly appreciated
Regards
Nigel
  • 11 months later...
i put one in my old navara d22 it work a treat still have a little slow start but not as bad as it was
    2. 5
    3. 0
      Tow bar
    4. 3
    6. 3
    7. 3
    8. 3
    9. 1
      Snapping wheel and axle studs
    10. 0
