Hi Guys!
Does any one knows how to correct rear toe adjustment of Toyota Tarago 2000 model acr30? Currently my car having negative rear toe and failed to get road worthy cert.
thanks
Sent from my iPhone using Tapatalk
I'm assuming negative toe means toeing out ? you will find it should be around 6 minutes in degrees or around 1 to 2 mm . you might want to replace to adjusting bolts depending on the age / kilometers of the van . If there is no adjusters , there might be something bent . Good Luck .
    2. 5
    3. 0
      Tow bar
    4. 3
    6. 3
    7. 3
    8. 3
    9. 1
      Snapping wheel and axle studs
    10. 0
