2000-2005 Toyota Celica Short Throw Shifter
Izaac Canny
MWR do a short shifter for the Celica that I have in my AE102 Corolla (the shifter housings are almost identical, and will be required for when I finish my 2ZZ/6-speed conversion), it's quite a bit shorter and notchy-ish (although I've only used it in the Corolla), quality is decent and it comes with the base spacers (which also act as solid bushes) to space the cradle up so the linkage doesn't hit the tunnel + a new lock pin and washer.  MWR often have their short shifters on sale but postage is a killer.
      1981 Hiace ignition upgrade
      Aftermarket Air Intake
      Heater problems
      Entertainment Unit Upgrade
      Seat change
