Advice topping up and checking coolant?
20ten
Hi theres,
I have a 2010 Toyota Camry.
Would like to know if I check the coolant while engine is cold, should the coolant be at the minimum line?
When the engine is cold, the coolant level should not be below the minimum line. I would suggest having the coolant level at the maximum line.
Actually, I have my coolant above the maximum line when the engine is cold. When the engine is hot, the coolant level is still below the top of the coolant overflow bottle. Now filled with long life coolant i.e.8 years but I still regularly check the coolant level whenever I pop the bonnet to check the engine oil level which is usually most Saturday mornings.
On the coolant overflow bottle there is a L [low] line and a F [full] line. Coolant expands with heat and goes from the radiator to the overflow bottle. When the engine is stopped and starts to cool down, coolant is drawn back into the radiator from the overflow bottle.
thanks for the explanation
Edited by 20ten
      ZRE182 Nudge bar
      2016 Hilux SR5 Coolant Issues
      What to say!
    7. 4
    8. 4
      RATTLING CAMRY 2013
