Posted (edited)
I have a 1996 Corolla with a 7A-FE engine.  A couple of weeks ago I removed the throttle bottle and cleaned it.  Since then the fast idle when the engine is cold hasn't been working as it should.  When I first start the car from cold it starts at around 1000rpm where before it was higher than that.  After 2 or 3 minutes the rpm slowly creeps up.  Also the accelerator pedal is quite stiff until the car warms up then it feels normal again.  Obviously I have disturbed something.  Any suggestions on what I should check ?
Thanks for any help
Mike
Edited by Kiwi
    2. 5
    3. 0
      Tow bar
    4. 3
    6. 3
    7. 3
    8. 3
    9. 1
      Snapping wheel and axle studs
    10. 0
