Hi I’m wanting to upgrade my pizza cutter spare, could anyone tell me if a Kruger 17” wheel will fit my current model RAV4 which has a 17” ??
cheers Graeme
0409824564
Short answer, I would say yes, but you have to consider offset and clearance for lock to lock turning. The wider you go, it may rub the inners when steering full lock.
Toyota design their wheel tyre combos for a reason and deviating from this can cause issues. It may be possible to go one up in size but Kluger wheel/tyre assemblies are quite hefty being 245/65/R17 and so not sure if this will work. Something to keep in mind.
Hopefully someone here who has attempted this here can chime in, but that's my 2 cents worth.
      Tow bar
    2. 3
    3. 0
    4. 3
    5. 3
    6. 3
    7. 1
      Snapping wheel and axle studs
    9. 2
