Intake mods
1. Removed charcoal mesh from airbox lid.
2. Cut off the chamber from the intake pipe, and covered the holes with silicone joiner & adhesive. Relocated vacuum nipple from the discarded chamber to the airbox lid.
3. Swapped vacuum hoses around to keep intake valve open permanently to the top runner.
Seems to have more pop up top, and a noticeable roar at full throttle. I'm happy 👍
IMG-20210515-124038.jpgspacer.pngspacer.pngspacer.pngspacer.pngIMG-20210515-124009.jpg
I've done exhaust mods as well so this sorta stuff goes hand in hand.
All I can say is have a poke around ur engine bay & check out ur intake. If ur happy with it, then leave it. 👍
      Drive shafts
    3. 10
      front brake calipers
      Drive shafts
    7. 315
    8. 10
      Dashlight dimmer
