Hey all ,
Just wanting some advice on here.
I have a Gen3 Camry and apparently the power steering pump is whining. When i look the p/s reservoir there is bubbles inside it .Now when i move the rack manually when the car is off there is alot of air in the system , enough so that the p/s fluid bubbles out of the reservoir. The current steering state does not have the traditional feeling of feedback and it drives like a car with electric steering car (extremely light). Heres the kicker though, there are no visible leaks on the rack or on the floor , just wondering what you guys think on establishing a baseline on where to start.
Thanks,
No experience with your issue so I did a quick Google search.
As a baseline, I would start with a visual inspection of the hoses and connections. Check the power steering pump and tighten any of the bolts.
Following YouTube video will give you an idea of how to locate the leak in the power steering system.
    2. 0
      Tow bar
    3. 3
    4. 0
    5. 3
    6. 3
    7. 3
    8. 1
      Snapping wheel and axle studs
    10. 2
