Marvin the ZZE122 Wagon
Hiro
So I went and did a thing the other day. Barring a KE10, we have now completed ownership of every single odd-numbered Corolla generation (3, 5, 7, 11 and now finally 9), and in some ways the fact that my pending existence caused my mother to have to sell her KE10 is kinda poetic (and ironic).
So, meet Marvin - both after Marvin the Paranoid Android from HHGTTG (the movie remake unfortunately, since the BBC miniseries version was silver rather than white), and Lee Marvin from the classic Western musical Paint Your Wagon (I was just stretching for any name connected to the word "wagon" really).
Pertinent details
2006 Ascent wagon
218k
Manual (I am pathologically unable to buy an auto if manual is a viable option)
All 3 cupholder dividers present and correct (apparently a minor miracle)
Boot room for days
Yes it will be getting some (minor) modifications
No I won't be putting the 2ZZ in to it instead of the 102
Yes I still have the 102
No it isn't finished yet.
by [url=https://www.flickr.com/photos/156852526@N07/]Ian Rigby[/url], on Flickr
Awesome find Ian, and to get the miracle of all 3 cup holders is very rare LOL keep us updated on Marvin's future
Keep Safe Mate
KAA
List of mods and fixes in the short-term future (depending on availability), in no particular order
Headunit (already ordered, factory unit not wired up due to previous owner doing a cut-n-shut)
Rear brakes (rotors and pads already ordered), brake shudder at higher speeds (>60k), fronts look OK though
Slimline weather shields
Front foglights
Power windows (at least fronts)
Towbar
Lowering (not excessive, still needs to handle gravel roads on occasion for bike trails/camping etc) + wheels
First mod done - replace the (disconnected) factory headunit with a Bluetooth/ACP/AA unit, so I no longer get bored ****less driving a 1ZZ down the freeway with no audio enhancement
Still need to get the reverse camera installed and wired up, but that can wait until the towbar goes on
Next step was trying to sort out the brake shudder - previous owner indicated that they had been told by the mechanic at last service/rego that the rears were almost done, so I figured that would be the first place to start.  Ordered new rotors and pads (didn't bother with the parking brake shoes), arrived quick-smart so got to work swapping them in....
Man I forgot how much I hated drum brakes.  Even though the rear brakes are disc, the parking brake works via shoes against the inside of the rotor hat, which means you have to back them off when replacing the rotors otherwise they can catch on a lip.  Well, it turns out that I mustn't have backed them off enough (or they stuck to the inside of the rotor), because when I pulled off the right rear (had to use the jacking screws because it wasn't coming by hand) the shoes had grabbed on to something and managed to _bend_ the entire backing plate (despite the only connection between the shoes and the plate being two nail-thin pins).  This meant that the new rotor (or the old one, for that matter) could not fit back over the shoes regardless of how much they were backed off, so I was up Schitt's Creek without a rowing instrument.
Cue a fit of inspiration to literally rip the entire parking brake hardware off the backing plate, smash the thing back as close to flat as possible with a sledgehammer, tie up the cable to the back of the hub and then make a break-of-dawn run down to Sydney the next day (with no working handbrake) to pick up a new wheel hub....which just turned out to be an entire rear torsion beam assembly, because it required less disassembly (and also gave a few spares).  Good thing I bought a wagon, and in a moment of poetic irony the first part the parts hauler hauled was literally it's own rear end (like a Babuskha doll)
All goes back together without a hitch, then the new rotors and pads finally fit and my brake shudder problems were solved.
Except they weren't.  So I figured that it must be the fronts, instead (not like there was any other option, apart from the uncomfortable possibility of excessive runout).  Didn't really have time before Christmas to order new rotors (at least pads I could get off the shelf), but fortunately I had a spare set of DBA T2s lying around that were slated to go on the ZZE102 (since the SuperStrut brakes run essentially the same 275mm front rotors).  Bit of overkill for a daily wagon hack, but time was more important and I wasn't driving up to Coffs to go camping over NYE with shuddering brakes.  At least these went in without a hitch (apart from having to take a few hours break whilst I tracked down which mate I had lent my caliper piston resetting tool to).  And lo and behold, the shudder was cured.
So speaking of camping, this was one of the reasons why we bought a wagon in the first place (other than being a parts hauler).  Still tonnes of room (pretty much from window line up to the roof)
Anyway, after we got back in the new year, I set about getting stuck in to the rest of the planned initial mods.  First up, towbar.  Should be simple, new towbar and straight car (no accident history) should mean everything lines up nice and neat, right?
Right?
Guess again.  Looks like Blind Freddy got a job at TAG some time last year, and welded together my towbar as straight as Mardi Gras
So now I've got to go through the hassle of an eBay return of a metre-long chunk of steel, which is always fun.  Still, at least the day wasn't a total write-off, as I acquired a set of 16" wheels to progress one step further along the path to Dad-bod Sportivo.
Short version, towbar now fits - just have to rip the interior trim out of the boot to see if there's any pre-wired plugs of whether we'll have to wire it in from scratch
Long version - measured the mounting points on the car with stringlines and plumbs, sent dimensions to manufacturer who confirmed that their entire _batch_ was out (must have been an issue with the jig if that's the case), sent out a new towbar adjusted to the exact dimension of what I had (just in case) and arranged for Toll to pick the other one up (so at least I didn't have to schlep to the post office).  One of the tow hook bolt holes was on the verge of stripping out however (not uncommon by the sounds of it) so had to chase it out with a thread tap, of course it had to be the one with the tightest clearance and worst access (muffler side, closest to bumper, and with a useless plastic tab on the bumper getting in the way).
Next up is chasing down a facelift ZRE152 steering wheel so I can have SWC for the headunit (although Android Auto is now broken due to my new phone, also seems to be a common problem with S22s).  Also picked up a full set of power windows/switches and door trims, at some stage I'll have to pull the interior apart and see how much is also pre-wired for them.
ZRE152 steering wheel now fitted, SWCs aren't hooked up until I can get a new clock spring (going to switch to black fascia too, silver doesn't suit the Ascent interior) but already feels tonnes better than the stock vinyl noodle-ring.
  • 5 months later...
No massive changes for a while, got a full set of foglights on their way but in the meantime I thought I'd raise the driveway about 25mm towards the chassis
Only went Lows as this still has to be a practical load-carrying daily.  Kings weren't my first choice but there are ridiculous wait-times for springs from Lovells these days (like 3+ months)
The de-Ascent-ifying of Marvin continues - brand new genuine foglights and surrounds (from the top-spec Levin), everything was pre-wired so just needed the relay (installed ages ago when we had the dash apart) and combination switch. Globes are selective-yellow Osram Fogbreakers.
Also finally got around to getting the black steering wheel controls w/ the hands free buttons installed on the ZRE wheel, I probably still prefer the silver but the blacks are growing on me.
  • 5 months later...
Amazing what a difference even just body-coloured door handles can make. Also replaced the front-left (passenger side) window belt moulding which was starting to peel quite bad.
Body-coloured rub strips are sitting here waiting to go on as soon as I can get a heat gun/hair-dryer and some goo-gone for the old weatherstripping adhesive.
And once again the wagon steals the good bits intended for the 102...swapped over the 101/111 Superstrut twin-piston brake conversion, figured I might as well make use of the pads and stop the seals drying out whilst the 102 stays off the road.
  • 7 months later...
You're doing exactly what I want to do with my newly acquired wagon, have you got your zre152r steering wheel fully functional? Does the airbag connect up okay? I'm currently in the process of fitting power windows from a conquest
Yes, ZRE steering wheel controls are fully functional (apart from the Display button, which is separate from the audio controls and would normally go to the instrument cluster - there aren't enough channels/wires on the clock spring for that one to work but I'm ok with that).  The airbag connects up fine and doesn't throw a code, I can only assume that it will function correctly in a crash as there's not exactly any way of testing it.
Which clock spring did you need to use to get it to work? I'm hoping to source the Fielder tailgate wing and front bar lip and side skirts. I was really happy about discovering that the loom plugs were there ready to accept the power window loom!
Edited by Matchu
ZZW30 MR2, I believe it's the same part number as the ZZE123 Fielder wagon one.  You still need to re-pin the plug on the steering wheel though, as the ZRE plug is different.
I haven't pulled the interior apart enough to work out if the body side of the power windows loom is there or not on mine, that's a task for a rainy week or 3.
That's quite a coincidence! I've got a zzw30 mr2 so that's very good to know.
As for checking if you've got the required plug for the windows, that's actually quite easy. The plastic panel at the bottom of the door jam just pulls off (only held in place by three clips, use a trim removal tool to pry it up) and then the kick panel plastic is only held in with one plastic screw clip. Pop that off and you'll see three plugs with only two occupied. Plugs will be coloured white, blue and grey respectively
Edit: I forgot to mention that this is on the driver's door jam.
Edited by Matchu
Additional information
Each time I see this thread pop up a thought runs through my head about the naming of your wagon.
I have to ask if you're a Frente fan..
They released the album "Marvin the Album" back in 1992. One of my favourite albums too mind you. They recently re released the 21st Anniversary version of the same Album.
Marvin the Album
Marvin the Wagon
Marvinthealbum.thumb.jpg.2f8e47ff69c80a571c70fad65e9d4a7f.jpg21stAnniversaryEdition.jpg.e23b3842a57bf367574a5a6b8872e8dc.jpg
Apart from Accidently Kelly Street, I can't say I'm familiar with their music.  As my first post described, the name is a combination of Marvin the Paranoid Android from The Hitchhikers Guide to the Galaxy, and Lee Marvin's classic Western/musical "Paint Your Wagon"
