2GRFE Aurion Start up Rattle
Frankminas
I would recommend that you view a few YouTube videos about the Toyota VVTi rattle issue. Following video shows the Toyota 1MZ engine being torn apart and a dismantle of the VVTi actuator.
Personally, I have given the VVTi oil control valves the occassional clean. I do regular oil changes including engine flushes to reduce/remove any oil sludge build up particularly in the valve cover and valve train.
Hi Frank.
Welcome.
At what mileage did the rattle start?
Based on that video it's not worth fixing unless you already have the valve covers off to do other work.
      Drive shafts
    3. 10
      front brake calipers
      Drive shafts
    7. 315
    8. 10
      Dashlight dimmer
