Low Idle 2004 Hilux KZN165.
LowIdleLuxy
My Hilux, 2004, Dual Cab, SR5, 1KZ-TE, 240 000km, has gradually had the idle lower over the last ten years or so. It now idles at about 750 with air con not running and obviously a bit more, 800, when it's on. I'm in Mackay so the higher revs are needed for the heat. I've tried lifting the pedal off the floor to help, zip tie around the throttle arm,  but it shuts it down to idle and has to be restarted. Checked a few of the hoses and they seem fine.
Any ideas on how to fix this? Surely not the first time this has happened.
      Corolla Seca For Sale
      Toyota Corolla Sportivo
    6. 2
      Toyota Landcruiser problems
    9. 7
      selling car
