2016 electric rear sunshade retrofit
88MATT
Hi all!
I’m new here, thanks for accepting me.
I just purchased a beautiful 2016 ATX. Just wondering if anyone has retrofitted the electric rear sunshade?
Thinking of picking one up from the wreckers.
What would I need just the switch and parcel shelf?
Thanks!
Edited by 88MATT
Edit title
Hi!
Welcome to the community.
To retrofit the electric rear sunshade in your 2016 ATX, you'll need the following components:
-Sunshade motor assembly
-Sunshade cloth
-Wiring harness
-Switch
-Parcel shelf (if not already present)
-Brackets and hardware for installation
It is advisable to get these components from the same vehicle model to ensure compatibility and a successful retrofit. If you are getting the parts from a wrecker, make sure they are in good working condition.
It's recommended to consult a professional installer or mechanic for the retrofit process, as it can be complex and requires electrical wiring knowledge.
      Rav4 smart key keyless entry
    4. 13
      Starter motor issues
    7. 3
    8. 3
