2zzge into 1zzfe gear box
I am sure either TRD, C-One, TOMs or Spirits manufacture close-ratio gears for the 5 & 6 speed gearboxes. They usually chnage the 3rd, 4th and 5th gears in the 6 speed and keep the final drive ratio. An LSD is also a common addition. Will cost a bomb though to get them from Japan and you would need a specialised mechanic to work on the gearbox.
I have a BM vid of a TOMs MRS Turbo (190ps) with the 1ZZFE and it had the stock 5 speed gearbox, and it was tearing up the touge.
Hmms i will go ask about these gear ratios.
A LSD? I know a LSD transfers the power equally to both wheels.
but does it help with the gear ratios?
No, it has no effect on gear ratios but probably reduces the amount of power loss through wheel spin during hard cornering which would be what you want with that much supercharged torque :P
    6. 21
    7. 21
    8. 21
