Corolla Cold Air Intake US$49.99
i dont recommend it to u guys..
my mate bought the otto brand from the u.s
about $150 AUD.. delivered with k&n filter.
we've tried fitting it 2 times... it doesnt fit securely and it has brackets that lead to no where.
With most US made intake kits, the brackets most likely will not fit correctly. Although the engine layout is the same, the fact is there steering wheel is on the left hand side. You could probably fabricate some yourself, I know that even the TRD ones will fit but the brackets do nothing. I think the CES ones have brackets to bolt them in, not sure though.
      Upgrade from 2012 to 2023
    3. 3
      Towbars
    4. 5
    5. 2
      ASV50 Camry Head Unit Options
    7. 2
    9. 1
    10. 14
