2007 Nissan Sentra SE-R Debut
http://www.worldcarfans.com/news.cfm/newsi...ntra-se-r-debut
The 2007 Nissan Sentra SE-R, which marks the return of Nissan’s legendary sport compact sedan, offers more power, performance and technology than any SE-R that has come before. It is available in two models – Sentra SE-R and Sentra SE-R Spec V, each utilizing an advanced 2.5-liter DOHC 4-cylinder engine designed specifically for the SE-R.
Special emphasis was placed on the SE-R Spec V’s new high output version of the QR25DE 4-cylinder engine, with extensive modifications to the top end of the engine that help the SE-R Spec V achieve 200 horsepower and 180 lb-ft of torque. Among the unique Spec V engine features are use of a unique resin intake manifold and dual branch exhaust manifold; revised piston crown shape to support a higher compression ratio (10.5:1); iridium tipped spark plugs for improved combustion characteristics; and a revised cam shaft profile, reinforced connecting rods and 8-counterweight crankshaft to achieve a higher redline limit of 6,800 rpm. The SE-R Spec V is available only with a close-ratio 6-speed manual transmission.
In the area of chassis, handling and braking performance, the SE-R Spec V is equipped with higher rate springs, shocks and bushings; 225/45WR17 uni-directional high performance tires; high capacity front disc brakes with 12.6-inch rotors; and a revised cowl top structure and a unique trunk mounted “V” brace, both utilized for increased body rigidity.
The SE-R model offers fun-to-drive performance and aggressive, sporty appearance to those who want the convenience of an automatic transmission. The QR25DE engine is tuned to deliver 177 horsepower and 172 lb-ft of torque (on regular unleaded fuel).
The Sentra SE-R is equipped exclusively with Nissan’s Xtronic CVT™ (Continuously Variable Transmission) with steering wheel-mounted paddle shifters.
Inside the Sentra SE-R cabin are a number of unique SE-R features, including an exclusive black interior color, sport bucket front seats with SE-R stitching, unique seat fabrics, red seat belts (Spec V only), aluminum foot pedal pads, leather-appointed steering wheel and shift knob, and an additional two-gauge meter pack.
Like all 2007 Sentra models, the new SE-R also offers an array of comfort and convenience features including standard power windows and door locks, air conditioning, AM/FM/CD 6-speaker audio, and an integrated overhead compact disc holder. Optional features include a 340-watt Rockford Fosgate audio system, factory installed satellite radio and Nissan’s Intelligent Key keyless entry system (SE-R only).
Standard safety features for the Sentra SE-R include an Advanced Air Bag System (AABS) with dual stage front air bags and occupant classification system for the front passenger seat, front seat side air bags, side curtain air bags (for front and rear outboard occupant head protection), front seat Active Head Restraints and Zone Body construction.
the front looks like a mix of a suzuki swift and a citroen c2
the body looks like a cadilac
is it fwd or rwd?
i pressume since it doesnt say anything about that that its fwd
so this is the next pulsar ^^; any takers?
      Where is the remote receiver on a 1998 Camry
    2. 27
      1987 Toyota Corolla - 60 000km on the clock
    4. 3
    5. 3
      Toyota Landcruiser problems
    7. 13
      300 series turbo issues
    8. 55
      Stout Owners
    9. 13
    10. 8
