melb d2 group buyers!!!
specialized32
i'm not in melbourne... but i had a little "we missed you" note from fedex slid under my door when i got in from work... 2 items (so andrew yours must be in too)...
can't wait for tomorrow...
Sweet as!!! :D I'll call you 2morrow.
btw what's happening with the installation Tom? Wanna do it together??
where are the sydney people going to get their put on? maybe a group install discount ???
I got my coilovers installed for $150, near liverpool catholic club.
All installed.
Some tips
- Adjust only from the bottom adjustments rather than from the top for the fronts
- Fix the sway linkage to the behind the coil rather than parallel otherwise it will rub
- The rears only have 1 adjustment so you havent got much choice but to compress them
- Put the everything from the top of your factory shocks on the rears except the bump stops (even the rubber thingy that sits on the coil cuz without it it creaks).
- I used 1/4 turn from hardest damening for the fronts and 1/2 turn from the hardest at the back (as per Goodboys)
Hope this helps
This topic is now closed to further replies.
