custom eyelids
MT
few years ago and maybe still now though i have not checked it out lately but using vinyl was quite popular in US probably because it took a while until shops started to produce aftermarket eyelids for their altis based corollas.
about light going through i am not sure but the vinyl mickytee got is black backed special 3M product called electro?
Marcus inspired this one, thought it might look ok if you joined the two bonnet gaps, if you get what i mean...
And this one which works on the theme of following the line of the bottom of the headlight with the line of the eyelid...
that sedan is in hong kong. the bodykit is from topline japan. i have not seen that bodykit outside japan until i saw that sedan and if you can afford it one good thing is that it has never been copied. the bodykit is available on yahoo japan auctions but you need to go through an auction broker to get it as the seller does not ship internationally.
i could just get a panel shop to slot an extra bar into my sports grille hey
I thought that look I gave you as soon as you mentioned this was indicative of the answer and subsequent result... :whistling:
Here's a replay for you micky: " <_< "
:lol:
Edited by Tayles
    2. 3
      Toyota Landcruiser problems
    4. 13
      300 series turbo issues
    5. 55
      Stout Owners
    6. 13
    7. 8
    8. 55
      Stout Owners
    9. 2
      New Member
