Posted (edited)
The battery is kind of hard to find one in the shop. You will need a CR1632 (ie 16mm in diameter, 3.2mm in thickness)
Jaycar in Melbourne sells it (www.jaycar.com.au)
You don't really need a screw driver like said on the manual. What happen you are in the middle of nowhere but has a replacement battery? :unsure: You can use the key coming from the remote - the end fits the slot perfectly
Pull the 2 clips on the side will release/drop the battery easily.
When replacing the cover - align the side opposite to the handle which releases the spare key from the remote (as shown on pic below). Once align that, you can press hard on the other side and it will close in place. Do have to use some force.
Edited by Taka
  • 2 months later...
Nice write up Taka I was wondering how to get into them, the dealer replaced our Batt last service
    2. 5
    3. 0
      Tow bar
    4. 3
    6. 3
    7. 3
    8. 3
    9. 1
      Snapping wheel and axle studs
    10. 0
