Hey there mate, sorry to hear about Toyota. With regards to brake pads, I believe those part numbers should be correct, but just to be safe you should ask for ZZT231 Celica pads (Not sure about the rears though if someone can shed some light on it). I believe he would've quoted you for Bendix pads. For an everyday road car, there are many pads out there which will suit your needs (except for cheap SCA sh*t), for example Bendix, EBC, QFM, Hawk, Remsa, etc. What you should make up your mind are what variant of brake pads you choose to run. In general, there is a trade-off between braking performance and longetivity/brake dust. The more performance-oriented the brake pads, the more they would chew through your brake rotors and the more dust would be produced, not lasting as long as a general brake pad. Depending what variant pad you purchase, it should be close to or exceed OEM pads' performance. The brake fluid I believe was DOT3? (Check on your brake fluid reservoir cap, I don't have a Corolla anymore so can't check). Any fluid meeting the DOT specifications would do, given that it should be flushed every 24 months regardless of mileage anyway. I don't understand what you mean by "let the brakes run through the pipes for a little while". The only 2 methods I've used for bleeding the brakes are; - One-man brake bleeder kits, and - A tube of piping which fits very snug over the bleeding nipple. After fitting one end on the nipple I submerge the other end in an old water bottle with a bit of fresh brake fluid (officially named my brake-bleeding bong). I hope my post helps.
