02/04/2012
Been focusing on correcting the EP3's suspension geometry after it was lowered with BuddyClub N+ coil overs. Bump steer was worse than it was before lowering.
So I got rid of the T1R inverted tie rod ends. They were noisy and steering started to feel loose (I assume pillow balls had a tiny bit of play in them). Replaced them with OEM DC5R tie rod ends (top mounted). This set my tie rods at an optimum angle to minimise bump steer - according to my research, the tie rod on a DC5/EP3 should be perpendicular to the angle of the strut in order to minimise/reduce bump steer.
Next, due to my current ride height, the LCA's began to slightly angle up. This caused my suspension to blow through it's range of travel each time I hit a bump. To correct this, in went a pair of J's Racing Roll Centre Adjusters. This is an extended ball joint compared to the OEM unit, therefore when installed it spaces the LCA at the outer most point so that the LCA points back down. Most importantly, it raises the roll centre, bringing it closer to the car's centre of gravity - i.e., less roll.
Overall, Über happy with the above two mods. Handling is great, cornering is flatter than ever, and the ride is more compliant over bumps. Ride comfort is firm, but not harsh.
Installed a padded harness guide insert to the passenger side Recaro. This prevents smaller people from banging their head against the harness guide during VTEC yO!
Lastly, gave the car some TLC - washing, claying, polishing, sealing, and waxing. Also had a few dings removed from around the body.
