Tyre fitment 2008 aurion zr6
whitezr6
Hi all,
just a few questions on fitting tyres on my 2008 aurion zr6
Currently
235/35 on 19x9.5 et +42
running altenzo tyres
wheels sit flush to guards
Now I am looking at better performing tyres than the altenzos which were $196ea
Looking at spending $300-$400
However with the tyre size 235/35 there is no other tyre with a load rating of 93+ that I could find, vendors or internet
my dilemma is going upto 245/35r19 (plenty of 93+ load rating tyres)
with my current setup:
Rears: (fronts plenty of clearance)
https://fbcdn-sphotos-e-a.akamaihd.net/hphotos-ak-xap1/t1.0-9/q83/s720x720/10361597_10202578477077314_1038612881821041753_n.jpg
https://fbcdn-sphotos-a-a.akamaihd.net/hphotos-ak-xfp1/t1.0-9/q71/s720x720/10325271_10202578476077289_9094858899292073190_n.jpg
https://fbcdn-sphotos-g-a.akamaihd.net/hphotos-ak-xpf1/t1.0-9/q71/s720x720/10306084_10202578475997287_8694977119120273322_n.jpg
https://fbcdn-sphotos-c-a.akamaihd.net/hphotos-ak-xaf1/t1.0-9/q79/s720x720/10325790_10202578476437298_1158686365089823001_n.jpg
Will I have any issues going from 235/35 --> 245/35?????
Also looking to lower till the frame rails are 100mm from the ground
Thanks for any advice/suggestions
Juan.
ps. looking at doing some test fitments at a local shop, just would like some/an idea's before booking it in
Bags. Airbags.
also, i dont see why you would have a problem. Getting 245 will get rid off some of that stretch.
Unless you're worried about rubbing ? Are your guards rolled ?
wish I had the $$$
only can dream
with 245/35 would the coils->tyre clearance be more than enough?
guards not rolled,currently no tyre->guard rubbing, dampeners are on setting 8 or 9 from hard
earlier the frame rails were 85mm(raised it 10mm, now want to re-lower 3-5mm) from the ground and didnt rub even with 5x65kg+ people in the car
http://www.willtheyfit.com/index.php?width=235&aspect=35&diameter=19&wheelwidth=9.5&offset=42&width2=245&aspect2=35&diameter2=19&wheelwidth2=9.5&offset2=42#content
245/35, not much bigger than 235/35 it seems
  • 3 months later...
      Front parking sensors
    2. 0
      Cruise Control Not Engaging
    3. 0
      Head Unit with Apple CarPlay
    4. 4
      2007 - Floor mat
    6. 4
    7. 4
    8. 46
      Lowering a Corolla ZRE
