Brake Noise Pinpointed
Hey everyone,
the brake noise is caused by the discs building up a rusty 'scale' on the surface area. This is caused by : Moisture in the air, and is more pronounced by either having cold/moist conditions, and/or leaving the car for a few days.
This can happen literally overnight if it is wet!!!
All it needs to clean the discs is a decent drive :D :D
Unless you change the discs to a different make, it will keep happening, and its down to the steel toyota uses. You will notice many brands of cars dicsc seem to "rust up" very quickly, and it is just one of those things. Even changing discs is no sure measure, as some "rust up" and some don't.
The reason it is more pronounced in reverse, is that the pads wear in a 'foward' direction, so reverse would make more noise with the scaling on the disc cos the pads are going against their natural direction.
I have it as well, and it is just "one of those things".
Yeah, it's most annoying when I wash my car and I have to wipe my wheels twice because the rusty water from the discs drips down and makes them dirty again ! Especially the fronts that are ventilated :angry:
