some sort of leak
excess stress through the CVs from hard launching, burnouts, deforming the joint when working on the suspension, or sometimes the rubber just deteriorates. Did you drive through any deep puddles during the rain on the weekend? This could also add extra stress to the joint.
not that i know of, when i see big pot holes, i usually avoid them. any ideas of the price on the repairs?
i had a nissan exa with a broken cv joint. cost me $80 to repair
ah really? thats not too bad
If there is nothing wrong with the CV joint them it will be resonably cheap to replace the boot but if you have a noise coming from it and the cv is buggered it will cost you a few hundred i would think
well the grease is all over the left side and the noise is coming from the right.
      Drive shafts
    3. 10
      front brake calipers
      Drive shafts
    7. 315
    8. 10
      Dashlight dimmer
