Not sure about sportivos, but they are usaully pretty big and usally requires a larger socket set ratchet (i.e. 3/4 inch drive)
do you mean the bolts on the flange or on the bearing hub side of the drive shaft?
bolt on outside of the hub, that holds the shaft in the hub
Posted (edited)
30mm deep socket. Cheapest is a 1/2" drive deep impact socket from tradetools which is about half the price of a 12 point regular 1/2" drive deep socket
Nuts are meant to be replaced with new ones when removed. Torque to 216N.m
Edited by rollamods
thanks, all the info i needed :)
This topic is now closed to further replies.
    2. 1
    3. 0
      Tyre Sale Specials
    4. 10
      Android auto
    6. 0
      Remote start
    7. 1
    8. 1
    9. 10
      Android auto
    10. 10
      Android auto
