RAV4 19" wheels on Aurion
Car drives nice with no scrubbing on low springs 👍 the nexen's on these 19's ride smoother than the chinese rubbish I had on the 18" rims that were removed from the car. Goes to show how much tyres can affect the ride quality. Only downside is the new wheels/tyre combo is nearly 3kg heavier per corner.- 1
Replacement springs for 2016 Aurion Sportivo
I don't know much about custom, but if anyone can help, it would be dobinsons. https://dobinsons.com/suspension/coil-springs Could always sell & get an older RAV4 with the 200kw V6. -
2008 Camry Altise - H7 Bulb Fitting/Loom
Hi, Is this the sort of thing you are looking for? https://www.jaycar.com.au/t10-wedge-globe-socket/p/SL2661?pos=1&queryId=70a0246df0e7ce2fa4e80eb666f9d820 Herb or do a search for h7 bulb plug many come up. -
Hi all, The small black plastic fitting (that the H7 Low Beam Bulbs clip into) have degraded/melted on my 2008 Camry Altise, does anyone know where I can buy just the small black plastic clips? Or will I have to replace the entire wiring assembly (the bit that goes all the way from the bulb back to where the wire plugs into the car)? If I'll have to replace the entire wire/assembly, does anyone know where I can get one of these from that won't break the bank? I've contacted a few wreckers and they will ONLY supply the entire headlight (the glass, the bulb, the wires) at a significant cost. Please let me know if any ideas, thanks all. -
Rav4 Screen changed unexpectedly
I have the odometer set to analogue and have Eco turned on. The odometer reading is always white on a black background. As I was driving along my street, 60kmph I glanced down and noticed that the odometer writing had turned red. Eeek! Red usually is a warning sign, right? There was absolutely nothing else on the screen to notify a warning of any sort. A few metres further along, it switched back to white. Does anyone have any idea what that was all about? Grateful for any input. -
Always found it a bit soft in teh suspension. Do you know of anyone who does custom springs? I haven't had any luck finding anyone. Should have updated the springs and sway bars years ago. Now shocks are gone so struts HAVE to come out, so ideal time to update stuff, unfortunately no one seems to make stuff any more. No chance of a new car as I am already spending more than I earn. No way I can afford a new car or even a newer car, which still will probably be too soft and scape the front and rear . A couple of years ago could have still bought KMAC bars but looks like they only do alignment stuff these days -
Lowering Aurion GSV50R
Hi guys First post for me also. I was just reading the email to Sam regarding lowering the GSV50R series and im glad to hear that there are lowered springs to fit the 50 series. As you have recommended Kings and Pedders, i am just struggling to find them to order online as it says that the product is not available. If you can send us a link for me to order these springs for my 2012 Sportivo ZR6 that would be great 🙂 thank you Mo -
6
Drivers side mirrors - zze122 vs zre122
THE BACKS ON MOST TOYOTA MIRRORS JUST CLIP ON SO YOU CAN SWAP THEM. INCREASED OIL CONSUPTION IS NORMAL FOR OLDER ENGINES. YOU CAN BUY OIL DESIGNED FOR HIGH MILAGE ENGINES, THAT WILL SLOW DOWN THE USEAGE, 1ZZ ENGINES USE OIL AFTER A WHILE, BUT IT IS NOT WORTH REPAIRING, IF YOU WANT TO KEEP THE CAR YOU WOULD BE BEST OFF SOURCING A NEWER ENGINE FROM A WRECKER OR ENGINE IMPORTER.- 1
6
