I am having problems with the central locking on my 2002 Tarago and was wondering if anyone knows how to remove the manual window winder handle on the sliding rear doors. I need to remove the panel to gain access to the locking mechanism.
cheers
If you push the door trim in a little bit at the base of the window winder you'll see a metal clip that holds the winder onto the regulator shaft...
Easiest way to remove it is to have the winder facing downwards and get a rag and slide it upwards between the winder and the door trim... Make sure you cover the top while you're sliding the rag upwards and moving it side to side as the clip will fling about 10 metres in the air and will get away from you...
Thanks for that info Ben..tried your method on the weekend and it did the trick :yahoo:
    2. 5
    3. 0
      Tow bar
    4. 3
    6. 3
    7. 3
    8. 3
    9. 1
      Snapping wheel and axle studs
    10. 0
