Hi I was just wondering if anyone knows if all the V6 gen4s & 4.5s have the same wiring harness regardless of the particular model.
I'm currently just trying to install the clock of a higher model but when I had a look at where the wiring connector would be all I found was a tied of group of wires covered with a seethrough red rubber thingy that may well be what I am looking for, I'm just not sure.I didn't want to frig around with it to much untill I'm sure in case it was a sensor or something else important.
Any help would be greatly appreciated.
im not sure but i *ASSUME* that each series would have the same harness coz it would b cheaper to make 1 and just not use connectors if that model didnt have that function/part
BUT they may have changed it from 4 to 4.5 i know this isnt much help but just puttin an idea out there
soz cant help u
good luck
not all the wiring harnesses are exactly the same, as far as I know. But for small accessories like clocks and stuff, they should have the connectors there but just don't use them on the lower models.
I used to have a Gen3 CSi which didn't have a clock, and I did exactly what you did and bought one from a higher model, the connector is there and as you have seen its tied up to the harness. So if your looking in the right area, that should be the connector your looking for ^_^
    2. 5
    3. 0
      Tow bar
    4. 3
    6. 3
    7. 3
    8. 3
    9. 1
      Snapping wheel and axle studs
    10. 0
